Date/Time: Sat, 04 May 2024 14:45:01 +0000
where is EUREX calendar spreads?
View Count: 532
[2021-03-01 17:38:50] |
User315851 - Posts: 27 |
I cannot get symbol for example, FESXZ20-FESXH21.FUT_SPREAD.EUREX
[2021-03-01 20:00:13] |
EUREX spreads are not yet supported. They will come later. But we do not yet have a date.
[2022-10-11 14:52:20] |
User758499 - Posts: 10 |
Any update on the Eurex calendars
[2022-10-17 20:40:23] |
Sierra_Chart Engineering - Posts: 14213 |
We are going to be doing some work on the EUREX data feed soon, and we will look at adding EUREX calendar spreads at that time.
