Date/Time: Mon, 06 May 2024 05:22:31 +0000
Datenfeed
View Count: 369
[2021-03-01 17:21:06] |
User253926 - Posts: 2 |
Data feed with CTS-Futures, account with DAW (dawtradingdiv.com) Good day. I have opened an account with DAW and ordered the data feed from CTS future. The DAW gave me credentials for Siera Chart. But they don't work. DAW says: "You need to enter it on the sierra chart download, Sierra customer service should be able to walk you thru it" Can you please help me? What and how should I do it? Thank you. Date Time Of Last Edit: 2021-03-01 17:21:13
[2021-03-01 19:25:48] |
CTS is no longer well supported by Sierra Chart. We recommend that you use one of the other supported services documented here: Supported Data and Trading Services We cannot provide technical help when using CTS. So you will need to decide to use one of the other supported services. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
