Date/Time: Mon, 06 May 2024 08:44:21 +0000
Crude Options
View Count: 443
[2021-03-01 15:48:52] |
User664240 - Posts: 206 |
I can't seem to get the Crude option settlement cell to populate. "LO". http://www.sierrachart.com/image.php?Image=1614613501241.png Date Time Of Last Edit: 2021-03-01 15:50:20
[2021-03-01 20:54:39] |
This would indicate the CME data feed is not providing that value then.
[2021-03-01 21:46:53] |
I strongly urge you to reconsider as I'm typing they clearly have posted today's settlement which SC notated but SC can't determine a net change without yest. sett. Just jump over to CQG and you'll see all the relevant INFO. If Not will know tomorrow if SC retains today's sett. or the issue repeats |
[2021-03-01 21:56:12] |
CME direct has yest.Sett at 717...for the M 5600. My goal is too eventually migrate to SC DATA/Order execution,but I need an accurate PnL through out the Day.
Date Time Of Last Edit: 2021-03-01 21:58:43
[2021-03-08 19:37:38] |
Hopefully you will take this more seriously as once again SC did not retain Friday's settlement price for LOM21 C5600. CME direct has settlement at 10.59 http://www.sierrachart.com/image.php?Image=1615232468582.png Date Time Of Last Edit: 2021-03-08 19:41:24
