Date/Time: Mon, 09 Nov 2026 19:55:05 +0000
CQG - Amp Customer
View Count: 1130
[2021-03-01 13:27:34]
User969241 - Posts: 155
I was using TT Fix and had to move over to CQG as an AMP client. I am very confused as to what to do . I signed up and logged in to the data/services with CQG Webapi.
I am reading that I should use Denali instead or that I can use the TTFix as the data feed but CQG will route the orders to AMP? How do I set this up other than using CQG as my data feed? I am very confused.
[2021-03-01 17:38:39]
John - SC Support - Posts: 48477
AMP should have already moved your account with them to use the CQG Order Routing. In which case, you would just need to follow the instructions here:
TT Based Order Routing Service: TT Interruption | Post: 252374
Since today is the first of the month, the Denali Exchange Data Feed on your account did not renew, as you did not have enough funds in your account. Therefore, you will also want to renew the Denali Exchange Data Feed. We recommend changing to Package 11 first, then renewing the exchanges for the CME Group. You can change your package here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#AvailableServices
And then the CME Group exchange options are here:
[2021-03-01 18:00:19]
Thanks. So which data feed do I then connect to when I sign in to Sierra? Does package 11 have market profile? I thought I had package 5 in order to make sure I had the market profile option.
[2021-03-01 20:47:49]
You will want to use the Denali Exchange Data Feed and for the external service would need to use CQG. Again, follow these instructions to get setup with CQG:
Yes package 11 has TPO Profile Charts.
Date Time Of Last Edit: 2021-03-01 22:05:44
