Date/Time: Sun, 28 Apr 2024 22:28:51 +0000
Advice before purchasing
View Count: 500
[2021-03-01 09:06:22] |
kaleem - Posts: 2 |
Hi Support, Im on trial atm. i want to purchase but before purchasing i want to select correct package. 1 : Currently on DOM i dont see "Bid Size/ Buy Column" and "ASK Size/Sell Column" both always show as 1, i want to see the size, thats for FOREX Pairs and SPX & NAS100 2: I would be looking at VWAP profiles in future but need correct package for that. thanks, kaleem |
[2021-03-01 16:52:17] |
1. There is no Market Depth data for FOREX or CFD. Refer to the information here: Sierra Chart Real Time and Historical Forex and CFD Data Service 2. VWAP is available in the Basic package (Package 3). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-01 17:06:06] |
kaleem - Posts: 2 |
Many thanks John for your help. so is market depth only for futures? is there any currency futures as well and symbols to look also, SierraChart Realtime feed doesnt show TSLA DOM, does that exist ? if yes which feeds i need to purchase to get that. thanks in adv. |
[2021-03-01 19:12:35] |
It depends on the particular exchange as to whether Market Depth is available or not. For Currency futures, look at what the CME Group has available here: https://www.cmegroup.com/trading/why-futures/welcome-to-cme-fx-futures.html We do have real-time data for U.S. Equities, but our data feed does not include the Market Depth (just the Best Bid and Ask). If you are interested, then look at the Sierra Chart Exchange Data Feed for this: Sierra Chart Exchange Data Feed Otherwise, you can get Level 2 Market Depth for U.S. Equities from Interactive Brokers. Refer to the information here: Interactive Brokers Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
