Date/Time: Mon, 06 May 2024 11:13:47 +0000
AMP has switched me from TT routing to CQG
View Count: 548
[2021-03-01 00:05:14] |
Mercantile_Man - Posts: 17 |
What settings do I need to change within SC regarding server-side OCO and brackets? They were previously both set to "Yes" when routing with TT. Cheers |
[2021-03-01 00:26:08] |
No changes needed. However, you will not have server-side bracket orders with CQG.
[2021-03-05 17:44:46] |
Meklon - Posts: 217 |
Support, does TT still supports regular servers side orders (none bracket)? If I place a stop as NONE-Attached order, will it still be held on the server side if I use TT or will it only be on the client side so if Sierra or internet goes down it will not be triggered?
Date Time Of Last Edit: 2021-03-05 17:45:06
