Date/Time: Fri, 03 May 2024 07:53:00 +0000
Order Lines Now Covered Up By Other Drawings As Default After Update?
View Count: 407
[2021-02-28 15:24:44] |
User414533 - Posts: 90 |
Hi, it appears after the last update or prior, the order lines are not default on top of all other drawings/text anymore. I went to Chart Settings/Advanced and then chose "Draw Non-Highlight Chart Drawings Underneath Main Chart Graph And Studies", but then it makes some of my other drawings dominant and everything looks messy. I just want order lines to be on top of everything as they should be like it was before. The rest of my drawings look perfect otherwise (unless I check the option noted above). To further clarify: if you have your text config set to opaque background and write some notes on a chart, then put a parallel channel on the chart, both will cover the order lines as well as the order info boxes. Even arrows cover up the order lines and boxes! This never happened before. I'm on version 2233. Date Time Of Last Edit: 2021-02-28 15:53:34
