Date/Time: Sun, 05 May 2024 10:15:59 +0000
Export trades live when they happen?
View Count: 464
[2021-02-27 18:13:55] |
User339484 - Posts: 71 |
I’m looking for a way to export or somehow pull data so an outside source can know when a trade has happened in Sierra charts. Example when I click to buy /es I want it automatically logs somewhere outside so I can use that data I know you can export the data manually or in the spreadsheet it will say but I can’t find a way to use those live as they happen. You might be able to do it with the DTC but that seems like going way overboard is there a simpler way just to know when I’ve entered a trade outside the program? |
[2021-03-01 22:59:06] |
You can use ACSIL and access the order fills and then do what you need with the data. Refer to the documentation here: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
