Date/Time: Sun, 19 May 2024 19:38:59 +0000
Number Bars separate threshold for text coloring and for background coloring
View Count: 431
[2021-02-26 14:28:50] |
Oceans - Posts: 12 |
Hello, I'm new to Sierra Chart and I'm trying to reproduce the Number Bars setup I'm used to in NinjaTrader. I set the Column 1 Background Coloring Method to "Based on Separate AskVol BidVol Percentage" I then set the Column 1 Text Coloring Method to "Based on Diagonal Dominant Side AskVol BidVol Percentage" I need a way to set a Bid/Ask Minimum Volume Compare Threshold separately for the background and for the text, since I need to always color the background (no matter a minimum threshold), but I need to see the imbalances by coloring text only over a minimum threshold. At the moment I see only one Input Value (n. 95) to set a general threshold that affects both background and text color. Is there a way to achieve what I'd need? Thanks in advance and congratulations for the platform in general |
[2021-02-26 15:31:08] |
John - SC Support - Posts: 31733 |
There is not a separate set of threshold levels for the text and for the background. The options that are available are to use different coloring techniques where one uses a percentage and the other uses Actual values. Or you can use one column for the background and another column for the text, which would give you the ability to set different thresholds as well. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
