Date/Time: Thu, 02 May 2024 18:18:05 +0000
Moving Average -Weighted Moving average Move - bug
View Count: 551
[2021-02-26 12:12:38] |
GravisHTG - Posts: 303 |
if you look at the picture. Sometimes it give me those spike. Its for the Moving Average - Weight Volume Move-Adjusted It happen only on my 1s chart and with the 8 MA maybe it happen on other X Ma Time frame and date on the picture 7:00:59 , on GME Other Example , 25 FEB 15:50, 100 tick chart. SPY 26 FEB at 9:01:51, 1 second chart. LIXT 26 FEB 9:05 to 9:20 , 1 sec chart , 8 MA and 13 MA , GTES thanks in advance. Date Time Of Last Edit: 2021-02-26 15:07:44
MA problem.PNG / V - Attached On 2021-02-26 12:11:06 UTC - Size: 81.3 KB - 164 views |
[2021-02-26 14:38:24] |
What is the time zone of those times?
[2021-02-26 15:02:33] |
NY -5 est
[2021-02-27 20:19:34] |
SYMBOL : SCKT timeframe 1s - 10s - 1M The 5 ma WVMA on those 4 time frame bug if you look at the picture. I think it might have to do something with very low to no volume on some of the candle when it does calculation. Still not sure. ( see pic 2 ) |
ma bug.PNG / V - Attached On 2021-02-27 20:19:08 UTC - Size: 194.45 KB - 200 views ma bug pic 2.PNG / V - Attached On 2021-02-27 20:19:13 UTC - Size: 212.2 KB - 165 views |
[2021-03-04 22:48:35] |
did you find why this his happening ?
[2021-03-05 14:43:30] |
John - SC Support - Posts: 31327 |
We are able to reproduce this, but we have not had a chance to look deeper into the issue and get it fixed. We should be able to get to this later today or over the weekend.
[2021-03-05 19:35:19] |
We have fixed this issue. It will be available in the next Pre-Release (v 2237). When available, you can update using these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
