Date/Time: Sat, 18 May 2024 08:17:01 +0000
Remain in Drawing Mode
View Count: 1599
[2014-02-27 10:36:50] |
User96105 - Posts: 113 |
Is there an option to remain in drawing mode? Example: I want to add a number of lines and a number text items to a chart, so I want to select "remain in drawing mode", select the Line Tool toolbar icon, go to the chart, left click and hold to establish the start/end points of the line, release the button, left click/hold to establish the next line (etc), then select the Type Text Tool (similarly add a number of items of text) ~ then exit out of "remain in drawing mode". This is to avoid having to go back to the toolbar each time. Is this possible? Thanks Date Time Of Last Edit: 2014-02-27 10:40:24
[2014-02-27 10:43:51] |
What you want is the default. Refer to the section here to disable the automatic tool switching: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#SettingtheDefaultTool Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-27 10:50:49] |
Great, and thanks for quick response...
[2014-02-27 13:41:57] |
Just a thought that it would be nice to be able to quickly toggle between "remain in drawing mode" (After single tool use change to = None), and the users' "normal" mode (I use Hand usually) by having a Tools Menu option which could be accessed via a Toolbar button. Many thanks Tony |
[2014-10-26 11:26:58] |
Toolbar button would still be very useful to quickly switch being "none" and "hand" (or the other options available). Thanks
