Date/Time: Fri, 26 Apr 2024 12:50:33 +0000
s_SCTradeOrder.OrderType
View Count: 1494
[2014-02-26 23:40:24] |
onnb - Posts: 660 |
s_SCTradeOrder.OrderType is a SCString where all the order types are enums. Is there a method that determines if the order type is a limit order? Even better, is there a method that determines if the order is a target order? If not, what is the recommended way for discovering a working order type in rum time? |
[2014-03-04 00:53:16] |
We are going to be working on this today. We plan some updates to the s_SCTradeOrder data structure. Refer to the updated structure in the next release.
[2014-03-21 12:19:49] |
onnb - Posts: 660 |
Are there docs on OrderTypeAsInt? If not, can you please provide some? Onn |
[2014-03-21 18:54:00] |
We will update the documentation for this member now.
[2014-03-21 19:14:30] |
It is now done. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html#GettingOrderInformation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
