Date/Time: Sat, 18 May 2024 19:51:09 +0000
Hotkeys for Constant Range Manual Mode and Keep The Last Bar Within View
View Count: 606
[2021-02-23 15:07:42] |
tdd2672 - Posts: 58 |
Can hotkeys be set up for each of these scale modes, Constant Range Manual Mode and Keep The Last Bar Within View? When setting up a Control Bar/Hotkeys I only see where I can choose Constant Range but not it's sub-options.
Date Time Of Last Edit: 2021-02-24 15:48:05
[2021-02-24 15:46:47] |
I've provided an image to support this inquiry/request. While trading from the chart I like to keep it on Manual Mode so the scale only moves when I click or drag. Other times, especially when I'm away from the screen, I want to switch it to Keep The Last Bar Within View. This is important when recording the screen. Ideally, I want to be able to switch between the two using hotkeys and have them assigned to a control bar.
Date Time Of Last Edit: 2021-02-24 16:35:06
Screenshot_1.png / V - Attached On 2021-02-24 15:41:29 UTC - Size: 11.27 KB - 202 views |
[2021-03-05 15:25:32] |
@Sierra Chart - Please implement this or let me know if the capability is already available.
[2021-03-05 16:01:24] |
User907968 - Posts: 804 |
You can add keyboard shortcuts for these (but not, as far as I can see control bar buttons). Customize Keyboard Shortcuts -> Chart -> Scale (see attached image) |
scale hotkeys.png / V - Attached On 2021-03-05 16:00:24 UTC - Size: 40.4 KB - 182 views |
[2021-03-05 22:49:52] |
Interestingly enough, when I go to set a keyboard shortcut and attempt to chose any of the Constant Range options they will not populate the Selected Command box, therefore they can not be assigned. All of the other scale functions can be assigned a hotkey. I've attached 3 images for reference. @Sierra Chart - Please look into this. It would be very helpful. |
Screenshot_10.png / V - Attached On 2021-03-05 22:48:57 UTC - Size: 29.34 KB - 188 views Screenshot_11.png / V - Attached On 2021-03-05 22:49:06 UTC - Size: 28.04 KB - 183 views Screenshot_12.png / V - Attached On 2021-03-05 22:49:15 UTC - Size: 27.89 KB - 197 views |
