Date/Time: Fri, 13 Mar 2026 19:49:01 +0000
request for multiple computer use under same account
View Count: 1374
| [2014-02-26 19:09:33] |
| User98399 - Posts: 3 |
Hi...I would like to have access to sierra chart using two computers. I am currently with amp futures with rithmic data feed. I am on the road alot so using my notebook to monitor /edit my trades would be great.
| [2014-02-26 19:17:39] |
For this you need a direct Sierra Chart account and you will be able to use Sierra Chart on 2 systems: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
