Date/Time: Mon, 29 Apr 2024 16:15:46 +0000
running backtests automatically
View Count: 659
[2021-02-22 20:39:26] |
User30743 - Posts: 364 |
is there any way to do automatic backtest? lets say i have a strategy and i want to run 100 of bectests, with different parameters (on one market). then another 100 bectests for another market. etc. is there any way to automate it? i don't want to run 10000000 times manually backest. |
[2021-02-22 22:27:35] |
GravisHTG - Posts: 303 |
their is one program that you can find on the net , i dont know if its really good or not , I once try to get one but end up to never use it. Sierra chart , at this moment, is more for live, simulated, market replay and automated trading than backtesting and finding good tuning in a Certain strat. I would suggest you to find another way or platform for backtest only. ( ex : Ninja Trader ) And then place the result in sierra chart. |
[2021-02-25 12:23:53] |
Well, and is it possible to run automatic bectesting on Ninja Trader or other platforms? The reason I want to stick with SC because it is C++ based code offering me some expresivenes, OOP approach etc. I dont know it other platforms offers the same when it comes to coding studies and systems. I can see SC engineering did a good job on ACSIL, they put together nice libraries and also their own compiler. It must have been a tremendous amount of work, so making the platform suitable for allround algotrading would make a lot of sense. I am curious if they have or plan to have some automation backtesting because that is the only thing really missing. Then I can go 100% auto only with SC. It should be possible I believe to implement something like this, and it would attract many people who are currently using other platforms for development of algo trading systems. Date Time Of Last Edit: 2021-02-25 12:27:40
[2021-02-25 12:33:13] |
User657945 - Posts: 226 |
I'm also searching for a backteting solution more fast and reliable than the backtesting available on SC but I did not find out anything that can manage fast using volume based signal. There a lot of solution to check OHLC but not whne you look at quant.Any suggetion will be appreciate
[2021-02-25 12:51:50] |
I am not much bothered about the time it takes to backtest data, though the faster the better of course. But what is a huge pain in the ass is to run the test by clicking a button. If there was a way to run the tests in a loop, I don't care it will take some time, I would just run overnight and in the morning had plenty of datasets to analyze.. So far I have tried PyWinAuto but with not much success. I am definitely going to dig into this because this is a crucial issue for me. Date Time Of Last Edit: 2021-02-25 12:52:16
[2021-03-01 00:53:59] |
Regarding the first post, refer to this function: sc.StartChartReplayNew() And there are various other Replay related ACSIL functions. You should be able to do what you want. There is a function to determine when a replay finishes and then you can start another one: sc.GetReplayHasFinishedStatus() And you can change study Inputs with this function and the other functions listed below: sc.SetChartStudyInputInt() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-01 00:56:08
[2021-03-01 08:41:20] |
yeah, i have already seen these, they could be used in some situations, but about bar-based backets? is there any function running bar-based back test? or how do i simulate it using acsil? and if it is not there, could you add it? |
