Date/Time: Mon, 20 May 2024 21:28:17 +0000
Moving from TT order routing to CQG
View Count: 594
[2021-02-19 00:53:30] |
aelagha - Posts: 31 |
I moved from TT to CQG already with AMP and still using Denali. Things seem to work so far. I have two questions: 1) do I still need to keep my subscription to SC Order Routing Service? 2) do I expect the $0.10/order TT charge to go away? I pay this directly through SC account. thx |
[2021-02-19 15:15:03] |
John - SC Support - Posts: 31754 |
1. You do not need to keep your connection to the SC Order Routing Service, unless you plan on changing back to it at some point. It also does not cause any issues if you leave it as it is. It is really your choice. 2. You will not see this same $0.10/order charge that you pay to us while you are routing your orders through CQG. Keep in mind that there are fees you will be paying for using CQG as well, so you will just need to look at your reconciliation to see how those are distributed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-19 17:49:02] |
1. There is no subscription for the Sierra Chart Order Routing service. However, you do want to stay using the Denali Exchange Data Feed. 2. That fee is no longer paid to Sierra Chart but then now goes to CQG and is paid through your broker. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-19 17:49:44
[2021-02-19 19:08:49] |
Awesome. Thanks
