Date/Time: Wed, 04 Nov 2026 14:21:37 +0000
TRIAL program pckg 5 with real-time data for US indexes
View Count: 705
| [2021-02-18 15:29:47] |
| P3dr0 - Posts: 1 |
Hello there, please, would you be so kind and allow me the trial program package 5 with real-time data for (M)NQ/(M)YM/(M)ES for thest current volatility? 1 week could be sufficient. It is several years ago I have traded last time US indexes and now I want to start it trade again after many years but at first I would like to test it with current volatility and situation because I have tried out NQ is much bigger and now there is 10x small e-mini micro which has practically same bigger volatility. Before I will start to use it with real money, I need to test it how does this work now and if it is still tradable with my strategy (Numbersbars, Volume Profile, Cum.Delta). Thank you very much Petr |
| [2021-02-18 16:34:40] |
| John - SC Support - Posts: 48413 |
We have activated the trial for your account. You have 15 days available, so the trial will end on March 5, 2021. In order to get the data, you will need to go through the Setup Instructions for the Denali Exchange Data Feed. The Data Feed and the exchange are both free for the remainder of the month in which you first use them. Therefore, if you were to activate it today, you would get the data for free until March 1, 2021 at which time you would need to make a payment to continue to get the data. You will find the Setup Instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Also, note the requirement from the CME Group that you need to have a funded trading account in order to qualify for the lower-priced Non-Professional Exchange Fees. If you do not have an account yet, then when you fill out the Exchange Agreements you will note yourself as a Professional and when you activate the exchange, you will be activating the Professional exchange. It will still be free for the remainder of the month. Then later, if you do get setup with a trading account, you can fill out the forms again to be considered a Non-Professional and switch to the Non-Professional exchange. Just make sure you deactivate the exchanges before the beginning of the next month or you will be charged for their use (if you have enough funds in your account). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
