Date/Time: Fri, 13 Mar 2026 20:54:01 +0000
Connecting IB and SC using Gateway
View Count: 1404
[2014-02-26 12:05:05]
User40117 - Posts: 56
i'm new to SC and IB, i would like to connect SC with my new IB account using the IB Gateway but use your SC Eurex Feed (because IB's feed isn't sufficient).
Is this possible ? Because your doc's refer to connecting IB's feed...
[2014-02-26 12:12:15]
Looks like i have to run 2 instances of SC to do this ?
[2014-02-26 17:29:22]
You only need a single instance of Sierra Chart to do this. This is explained here:
http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration
