Date/Time: Sat, 04 May 2024 02:19:12 +0000
[Locked] - Untrue Rumors
View Count: 1410
[2021-02-17 19:02:50] |
We been hearing some rumors that are untrue. 1. IQ Feed is going to be discontinued by Sierra Chart. Untrue. 2. For real-time EUREX data, you will have to use the Sierra Chart order routing service. Untrue. Yes we may very well have a requirement to get EUREX data through our new EUREX data through the Denali Exchange Data Feed but that works across all services including CQG. You can trade wherever you want. And no firm decision is being made in regards to that. It is a statement of intention . And only would be put into effect, once we have a proven track record with our new EUREX data feed. Currently there are couple of outstanding issues still. And to be very clear, the Denali Exchange Data Feed and the Sierra Chart Order Routing Service are totally separate from each other. The Denali data feed is a data only service which works with all supported services and also independently. 3. We have never represented the Denali Exchange Data Feed, to be an order routing service or to be associated with the Sierra Chart Order Routing Service. It is a data feed only and always represented it that way. We think some brokers have been representing it differently. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-18 09:41:22
