Date/Time: Mon, 06 May 2024 12:02:05 +0000
Euronext with Denali Exchange data feed
View Count: 733
[2021-02-17 15:37:06] |
vice&virtu - Posts: 43 |
Hello, I had read on your documentation once that Euronext would going to be part of your Denali Exchange data feed service. Unfortunately since, i have never read anything new about it . So i would like to know if there are a plan to extend the Denali data feed to Euronext or you have decided to phase out the actual SC feed at the end of the year ? Thank you . |
[2021-02-22 15:37:42] |
I bring up this unanswered question. Thk. |
[2021-02-22 16:12:44] |
No, definitely this is something that would not be offered through the Denali data feed.
[2021-02-22 22:20:38] |
So to be clear and to conclude , the Euronext data feed will be definitely removed at the end of this year when you will stop with the real-time SC Exchange data Feed ? It is an important question for me for anticipe it and take some decisions now. Thank you. |
[2021-02-22 23:49:17] |
If we end the SC Exchange Data Feed that would be the case but that is still an unknown whether that data feed would be removed. At this point we do not definitively know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-22 23:49:35
[2021-03-01 14:25:02] |
Hello again, On your message #3 you say :"No, definitely this is something that would not be offered through the Denali data feed Is it based on the fact that : 1)It is a complicated technical issue ? and/or 2)It is an expensive connection ? and/or 3) You don't have demand for it at all ? and if 3) only, then how many demand you would need to reconsider your position on the Euronext futures feed (active contracts on FCE,FTI,OBX and soon Milano ) ? By the way i have seen that recently you are proposing delayed Euronext equities. Regarding the fact that Euronext has became the first european equities market and this even before Italian market integration with a 20B€ exchanges/day that is four times DB and 2 times London, is this feed supposed to remain isolated or do you have other project to make it evolve ? Thank you by advance for your answer. |
[2021-03-01 22:09:55] |
We really cannot give you any definite answer in regards to these exchanges. Although certainly this is all true: 1)It is a complicated technical issue ? and/or
2)It is an expensive connection ? and/or 3) You don't have demand for it at all ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-01 22:10:03
[2021-03-02 08:51:20] |
stephane1 - Posts: 110 |
Hello, I agree with "vice&vertu". Currently, a real-time Euronext data feed would be welcome. With friends we are waiting to have euronext equities data to renew the subscription to SC. Have you got dead line? Have you given up on the idea of providing a Euronext data feed? tku |
[2023-12-22 23:51:31] |
wearslim - Posts: 1 |
Up ! I wanna trade on Euronext, cash. Trough which data feed provider can i have cac40, ibex, dax etc ? Thank you. |
[2023-12-23 01:51:55] |
Sierra_Chart Engineering - Posts: 14239 |
Check with Interactive Brokers which Sierra Chart supports for Euronext.
