Date/Time: Wed, 04 Nov 2026 14:21:26 +0000
CQG data
View Count: 930
| [2021-02-16 15:20:45] |
| User856747 - Posts: 7 |
Hi there, I have AMP futures account with CQG data. When I open Sierra chart, I am unable to enter my credentials, because when I choose Data/Trade Services, I couldnt find where to enter my credentials. I tried with CqG Webapi, but without success. So how to connect my CQG data with my account ? Thanks in advance
| [2021-02-16 17:55:21] |
| John - SC Support - Posts: 48413 |
First thing we want you to do is to update to the current version and then see if you continue to have trouble. Instructions: Software Download: Fast Update Also, refer to the information at the following link for how to use the new Settings windows, as it could be that you simply need to select the A button (or Apply) after changing the service to get the updated options for that particular setting chosen. Settings Windows Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-17 00:03:36
| [2021-02-17 13:07:19] |
I have the current version. Which Servece should I choose in order to enter my CQG data ? Thanks
| [2021-02-17 13:27:53] |
You need to use "CQG Web API".
