Date/Time: Sun, 05 May 2024 10:40:29 +0000
problem getting DAX data
View Count: 487
[2021-02-16 15:20:30] |
User633898 - Posts: 28 |
Hi, I have problem getting data for DAX futures. Following prompt showed when I download the file. "Download failed Error downloading historical intraday data for FDAXH21-EUREX. Historical data logon error. Data files folder not set for service code: eurex" Can you please advise what has gone wrong? Thanks Alex Choi |
[2021-02-16 15:35:53] |
John - SC Support - Posts: 31362 |
We need you to update to version 2230 or higher following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-16 15:57:58
[2021-03-02 10:28:01] |
I have updated to latest version but DAX chart showed delayed information. Does it come inclusive of the Denali service package and data feed? Or it requires additional data feed cost? |
[2021-03-02 11:24:40] |
You need to activate the EUREX exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedNonCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
