Date/Time: Mon, 13 May 2024 21:55:52 +0000
EUREX
View Count: 410
[2021-02-15 16:25:38] |
User391959 - Posts: 17 |
Hi I have already updated SC to 2230. It works fine with any products but not with EUREX Futures. I cannot receive historic EUREX data. I can se RT Price and Market Depth on EUREX Futures. It does not download historic data. I think the migration to the new Denali was not successful in my case. Thanks for your help |
[2021-02-15 16:51:34] |
Make sure you update all of your installations of Sierra Chart following these instructions: Software Download: Fast Update We see some of them are not up to date. Also, follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
