Date/Time: Sat, 27 Apr 2024 12:28:27 +0000
Number bar Volume imbalance
View Count: 1844
[2014-02-25 21:18:47] |
TradingMarketProfile - Posts: 120 |
Hello, is it possible for you to add 1 or 2 options in colomn color ? Because the maximum % is 76-100%, i would like 200-400%....100% is not enough to see real imbalance between the bid and the ask Thanks |
colors.PNG / V - Attached On 2014-02-25 21:18:41 UTC - Size: 12.04 KB - 450 views |
[2014-02-25 21:25:22] |
This is done by adjusting the Column # Compare Thresholds: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#ColumnCompareThresholds When you specify numbers greater than 1, then they still remain as percentages when using the "Auction" Text and Background coloring methods. The documentation is going to be updated to clarify this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-30 03:37:16
[2014-02-25 21:37:11] |
Ok thanks but it's difficult for me to understand very well.. So if i want 200% différence, what number i have to add, please ? |
[2014-02-25 21:43:02] |
It will be best if you wait for the updated documentation. It will be done by morning.
[2014-02-25 22:20:47] |
ok thanks i will do that
[2014-02-26 16:46:09] |
hello, Did you do the update ? |
[2014-02-27 17:51:03] |
Al SC Developer - Posts: 434 |
The doc is being updated today. Use a value of 200 to get 200%.
[2014-03-30 03:37:39] |
We have reviewed the Market Delta documentation. This capability is fully supported in Sierra Chart and is known as a Numbers Bars Diagonal Dominant Side coloring. "Diagonal" will be the new term to describe it since it is a very intuitive way to understand rather than the term "auction". Here are the step-by-step instructions to use this feature: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#DiagonalComparison The percentages can be changed. So you can program any percentage comparisons that you require. The documentation refers to version 1114 terminology. Update Sierra Chart by selecting Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-30 03:45:09
[2014-03-30 03:45:25] |
We gave the wrong link in the prior post. Here is the correct link: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#DiagonalComparison Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
