Date/Time: Wed, 08 May 2024 06:54:35 +0000
Numbers Bars
View Count: 1336
[2014-02-25 20:30:54] |
User31408 - Posts: 23 |
dear all, I am trying to set up on Sierra the Volume Imbalance of Market Delta. Could you please tell me if there is a function that can shows the x% more volume traded on the bid and x% more volume traded on the ask. x : represents a percentage for example 300% or 500%. If anyone knows how to do, please let me know. Marc |
[2014-02-25 20:32:37] |
The Sierra Chart Numbers Bars study can do this. We are going to be working on documentation for this because this question has been coming up recently.
[2014-02-25 20:36:25] |
thank,
[2014-03-11 04:25:31] |
The updated documentation can be found here: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-30 03:40:48] |
We are not quite sure how well you understood the documentation at the time we posted it. We have done further documentation updates and have provided step-by-step instructions for this feature. This capability is fully supported in Sierra Chart and is known as a Numbers Bars Diagonal Dominant Side coloring. "Diagonal" will be the new term to describe it since it is a very intuitive way to understand rather than the term "auction". Here are the step-by-step instructions to use this feature: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#DiagonalComparison The percentages can be changed. So you can program any percentage comparisons that you require. The documentation refers to version 1114 terminology. Update Sierra Chart by selecting Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-30 03:44:15
[2014-03-30 03:42:20] |
If you would like a trial extension, please let us know.
[2014-03-30 03:44:30] |
We gave the wrong link in the prior post. Here is the correct link: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#DiagonalComparison Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-30 03:44:44
[2014-03-30 03:52:01] |
The answer we have given in the post above is a standard response we have been giving in several threads asking similar questions. We are not sure whether you want to do a diagonal comparison of the bid volume and ask volume or only at the same price level. You can do a comparison at the same price level. In this case you just need to use a Column 1 Text Coloring method of Text on Dominant Side Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-12 09:30:30
