Date/Time: Tue, 14 May 2024 09:42:30 +0000
Numbers Bar Marker Color
View Count: 416
[2021-02-13 02:18:53] |
SpearChucker - Posts: 101 |
I must be missing something. I can only get a one color bar on the numbers bar(see image). These are 30 min. bars.
Date Time Of Last Edit: 2021-02-13 02:19:34
Markers.jpg / V - Attached On 2021-02-13 02:18:05 UTC - Size: 438.26 KB - 173 views |
[2021-02-13 08:02:11] |
Provide that particular chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-13 12:32:53] |
Here's the chart.
NumBar.Cht - Attached On 2021-02-13 12:32:21 UTC - Size: 4.36 KB - 150 views |
[2021-02-15 14:58:03] |
John - SC Support - Posts: 31602 |
The reason for what you are seeing is due to your Chart Setting for Graph Draw Type being set to Point and Figure XO. If you change that to Candlestick or OHLC, then you will get the coloring correctly.
