Date/Time: Wed, 04 Nov 2026 14:34:45 +0000
Mini and Micro Currency Futures
View Count: 907
| [2021-02-12 17:18:27] |
| Mattc55 - Posts: 101 |
Hello, Have you all corrected the issues associated with E7,J7,M6A,M6E,MCD? Can we trade them now? |
| [2021-02-12 17:26:11] |
What issue is this? Maybe you are referring to what is documented here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#UsingTradeSymbol (Using Trade Symbol) If so, the answer is yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-02-12 17:29:16] |
There was an issue with the multiplier. You’d enter an order and it would get rejected because the decimal was off and the error was that it’d say the order was outside exchange limits.
| [2021-02-12 17:38:27] |
Yes this is resolved but you just need to follow the instructions linked above.
