Date/Time: Wed, 15 May 2024 09:40:38 +0000
Historical Daily Data Error
View Count: 433
[2021-02-10 10:19:22] |
Vladislav Kravchenko - Posts: 39 |
Hello. I have different previous day close lines on Historical Daily Data and on Intraday Daily Data. I have provided you a screen and on the left and right you can see there are different close lines of previous day. How can I gat the right Historical Daily data chart? |
1. Historicla Daily error.png / V - Attached On 2021-02-10 10:18:59 UTC - Size: 228.8 KB - 153 views Attachment Deleted. |
[2021-02-10 10:32:23] |
I have checked Historical daily data open and Intraday data open - they are different absolutely. The Historical data is wrong. How can I change it? |
[2021-02-10 10:35:38] |
I have checked CME chart as well - they are different with Sierra Historical Daily Data. It is not good. How to fix it? |
[2021-02-10 13:15:29] |
Refer to: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.6 - Differences Between Close Prices on Historical Daily Charts Compared to Intraday Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-10 13:29:48] |
I have Windows error code 1314 for that: Software version: 2226 64-bit | 2021-02-10 15:29:29.707 Safe Mode enabled | 2021-02-10 15:29:29.707 Primary Thread ID: 6696 | 2021-02-10 15:29:29.707 Usage end date: 2021-03-05 | 2021-02-10 15:29:29.707 Enabled for: Sierra Chart Historical Data Service. | 2021-02-10 15:29:29.707 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-02-10 15:29:29.707 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-10 15:29:29.707 Enabled for exchange2: CME (Trading Account Required) | 2021-02-10 15:29:29.707 Enabled for exchange2: CBOT (Trading Account Required) | 2021-02-10 15:29:29.707 Enabled for exchange2: COMEX (Trading Account Required) | 2021-02-10 15:29:29.707 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-02-10 15:29:29.707 Enabled for exchange2: EUREX | 2021-02-10 15:29:29.707 Enabled for exchange2: EUREX EOBI | 2021-02-10 15:29:29.707 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-10 15:29:29.707 Current selected Data/Trading service: SC Futures Order Routing/Data | 2021-02-10 15:29:29.707 Custom symbol settings values: disabled | 2021-02-10 15:29:29.707 Chart Update Interval: 500 | 2021-02-10 15:29:29.707 Intraday Data Storage Time Unit: 0 | 2021-02-10 15:29:29.707 Time Zone: +02:00:00 (SAST+02) | 2021-02-10 15:29:29.707 2021-02-10 13:29:29 Local computer time in UTC | 2021-02-10 15:29:29.707 2021-02-10 15:29:29 Local computer time in SC Time Zone | 2021-02-10 15:29:29.707 2021-02-10 09:09:32 Server time in UTC | 2021-02-10 15:29:29.707 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-02-10 15:29:29.707 Program path: E:\1. Programs\SierraChart\ | 2021-02-10 15:29:29.707 Data Files path: E:\1. Programs\SierraChart\Data\ | 2021-02-10 15:29:29.707 OS Version Number: 10.0 | 2021-02-10 15:29:29.708 Locale Setting: C | 2021-02-10 15:29:29.708 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-02-10 15:29:29.711 Allowed protected custom studies: | 2021-02-10 15:29:29.711 Requesting current DateTime from Sierra Chart server. | 2021-02-10 15:29:36.223 Received Date-time from server. Delay adjusted UTC Date-time: 2021-02-10 13:29:36.386. Round-trip delay: 00:00:00.094 | 2021-02-10 15:29:36.412 Computer time to server time difference: 00:00:00.026 | 2021-02-10 15:29:36.412 Error setting System Date-Time. Windows error code 1314: Клиент не обладает требуемыми правами. | 2021-02-10 15:29:36.413 * |
[2021-02-10 13:37:17] |
Which data then should I use for analysis to be more correct in any assumptions? To use intraday data with changing chart to Daily or to use Historical chart? |
[2021-02-10 15:16:01] |
For the correct daily close price, you do need to use a Historical Daily chart.
[2021-02-10 16:25:38] |
How do I need to understand then the price which has close on intraday chart? I am trying to understand why Daily close, but not Intraday daily close. Because there are still some trades above or below the close price which from Historical chart and they bring the value. Why then the close from Historical chart is more valuable than close price from Intraday chart? |
[2021-02-10 18:33:44] |
You need to contact the exchange about this. This is not within the scope of our support.
