Date/Time: Thu, 02 May 2024 05:00:17 +0000
How to NOT get confirmation of order change popup when trading from charts
View Count: 1124
[2014-02-25 14:19:22] |
djcurcio - Posts: 236 |
When I drag an open order on the chart I always get a popup confirmation request of Transact order change box. How can I eliminate this? Thanks |
[2014-02-25 15:51:57] |
vegasfoster - Posts: 444 |
Click M on the trade window, then select Confirmations, then make sure each one is unchecked.
[2014-02-25 16:43:35] |
This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#MenuButton Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
