Date/Time: Sun, 12 May 2024 20:34:29 +0000
[Locked] - Important - Program on load dll missing and message log/studies issues
View Count: 563
[2021-02-08 11:25:06] |
User92573 - Posts: 489 |
Dear Engineering I have 2 issues I'm noticing with Sierra Chart (V2222). 1) I'm receiving errors messages when loading without anything else applied. 2) When I go to select "Custom" studies I'm getting what seems like a memory issue? * No custom studies exist other than those provided in the program itself. * C:\SierraChart64\Data\SierraChartStudies.dll; is in this location. Comments and details taken from log. As soon as I right-click studies on any chart the message log records (line 2): Socket (3) | Closed. | 2021-02-08 11:03:19.855 Failed to get the function address for scsf_OneTimeFraming in C:\SierraChart64\Data\SierraChartStudies.dll. Error: Windows error code 127: The specified procedure could not be found. | 2021-02-08 11:03:52.370 * Then when I select "Custom Studies" from the options the message log then adds the next line (line 3). Socket (3) | Closed. | 2021-02-08 11:03:19.855 Failed to get the function address for scsf_OneTimeFraming in C:\SierraChart64\Data\SierraChartStudies.dll. Error: Windows error code 127: The specified procedure could not be found. | 2021-02-08 11:03:52.370 * Loading DLL: C:\SierraChart64\Data\UserContributedStudies_64.dll. Handle: 7ffa79ef0000 | 2021-02-08 11:06:27.088 ** "Handle: XYZ" reference occurs in the message log against every custom study loaded. Please comment as soon as possible as I'm concerned this may be corrupting or causing issues with my charts/studies. Many thanks. |
[2021-02-08 11:41:20] |
Ackin - Posts: 1865 |
C:\SierraChart\Data\SierraChartStudies.dll error. Update Sierra Chart to the current version following the instructions here: Software Download: Fast Update |
[2021-02-08 12:45:26] |
Update Sierra Chart to the current version following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-08 13:32:34] |
Thank you the (scsf_OneTimeFraming) error seems to have disappeared with version 2226 Failed to get the function address for scsf_OneTimeFraming in C:\SierraChart64\Data\SierraChartStudies.dll. Error: Windows error code 127: The specified procedure could not be found. | 2021-02-08 11:03:52.370 * However with no other study dll's in the data folder I am still getting the following message as soon as I select studies >> custom studies. Obviously, when I add my own they will also all show the same message. Socket (3) | Closed. | 2021-02-08 13:23:46.149 Loading DLL: C:\SierraChart64\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffa56d00000 | 2021-02-08 13:25:10.474 Look forward to your thoughts. |
