Date/Time: Sat, 11 May 2024 11:26:56 +0000
Stock Order Routing using "Sierra Chart Real-Time and Historical Exchange Data Feed"
View Count: 453
[2021-02-05 02:19:57] |
User96296 - Posts: 28 |
I love "Sierra Chart Futures Order Routing Service With Denali Exchange Data Feed" with AMP. Can IB clients submit stock orders in SC using "Sierra Chart Real-Time and Historical Exchange Data Feed"? Any other brokers? |
[2021-02-05 15:26:52] |
John - SC Support - Posts: 31534 |
Sierra Chart can be used with Interactive Brokers for Stock trading. And yes, you would use the Sierra Chart Real-Time and Historical Exchange Data Feed and you would enable the U.S. Equities exchange to get the Real-Time stock data. We just want to point out that if you will be using Sierra Chart with both AMP and IB, then we recommend installing two separate installations of Sierra Chart, one for trading futures with AMP and the other for trading stocks with IB. This way you will not have to switch the service back and forth to connect to one then the other. Refer to the following: Using Multiple Data and Trading Services at the Same Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-08 13:39:53] |
Documentation for using this data feed and integrating it with Trading services is here: Sierra Chart Exchange Data Feed: Setup Instructions You will need to use the US Equities exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
