Date/Time: Sun, 28 Apr 2024 16:15:49 +0000
Trade Activity Log window issues
View Count: 1830
[2013-04-19 14:55:52] |
FFTrader - Posts: 180 |
Per the Trade Activity Log window, I noticed that within the boxes to set Date Range, the "From" date range box did not have the correct day of the week. April 19, 2013 - today - is listed as Thursday - it should be Friday. Additionally, once I set the date range - say for the "Trade Statistics" tab - the date range in the tab does not reflect the changes in the date range set above. What gives? |
[2013-04-19 17:08:56] |
Manually change the From date to what you require. It is ignored when you have enabled "Today". Simple thing to do. You need to press the "Apply" button after changing the Date-Time range. This is clearly documented. Please refer to the documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
