Date/Time: Fri, 10 May 2024 13:42:07 +0000
Datafeed question
View Count: 495
[2021-02-03 21:45:56] |
mazzy /| blast - Posts: 54 |
My goal is to run 1 instance of SC on a VPS in the US for CME trading and another 1 SC instance on a VPS in Europe for EUREX trading. I understand that SC + Denali can run concurrently on 2 systems by default. What about datafeeds, should I pay for 2 systems or just 1 ? I mean, I will separate the connectivity. On a single VPS I will chart / trade either EUREX or CME but never both at the same time Date Time Of Last Edit: 2021-02-03 22:30:11
[2021-02-03 22:28:51] |
More interrogation... I do see that for CME data within Denali, the number of system (1 or 2) needs to be picked then it eventually doubles the price. However, for EUREX data under the SC datafeed, I see no such thing as picking the number of systems. https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#SetCountryState Does it imply EUREX can be paid once and used on 2 concurrent systems that SC permits ? What about when EUREX will be integrated to Denali ? For EUREX on 2 systems, pay once or twice the data subscription ? Date Time Of Last Edit: 2021-02-03 22:30:56
[2021-02-08 08:20:21] |
Since the CME Group and EUREX are separate exchanges, you do not have to pay two exchange fees/connections when using the Denali Exchange Data Feed. You can have two connections. One for EUREX and one for CME. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-08 08:20:31
