Date/Time: Sat, 04 May 2024 10:44:45 +0000
NVOL-NYSE in place of $NVLF
View Count: 1171
[2014-02-24 19:51:19] |
WarriorTrader - Posts: 245 |
Hello, I noticed that the NVOL-NYSE numbers are a lot larger than the $NVLF numbers. When I tried to add a "TPO Value Area Lines" study to the NVOL-NYSE chart, the study went into an infinite loop. [have done infinite loops in SC a lot on my own :-) ] Thx, WT |
[2014-02-24 21:29:35] |
We have increased the Tick Size for this symbol to 1000. This is what you need to use to minimize processing with the study you are using. There is not an endless loop but instead a lot of processing that takes a long time to complete. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-24 22:18:20] |
Actually I tried that already but did not want to bother you with the details. I even increased the tick size to 100 million - now it does not crash, the study just does not show up. Thx, --Wt |
[2014-02-24 22:45:39] |
We do not recommend using the TPO Value Area Lines on a symbol like that.
