Date/Time: Sat, 27 Apr 2024 17:42:02 +0000
Sierra Chart/CQG
View Count: 2040
[2014-02-24 18:31:10] |
Luke - Posts: 142 |
I am with AMP and currently can execute my trades through SC/ttnet and SC/rhithmic. If I understood the info on your website correctly, I cannot use my ttnet or rhithmic feed only for charts and execute trades through SC/CQG without subscribing to the SC futures feed? I understand that there is no market data available for charts with CQG, but does that mean that there is also no data available for the trading dom (best bid/ask, last price) without the SC futures data feed?
[2014-02-24 18:36:12] |
Yes, this is a correct understanding. You need to use the Sierra Chart futures data feed for data when using CQG.
[2014-02-25 15:47:31] |
ABTrader - Posts: 32 |
What about logging and writing CQG data feed (utilizing CQG RTD Excel function to SCID file ) using www.everytick.com ? Will this works for SC with CQG FIX order routing ?. |
