Date/Time: Sat, 18 May 2024 06:23:10 +0000
close chartbook change or remove windows sound
View Count: 623
[2021-02-02 00:00:16] |
whats1thingnow - Posts: 407 |
hi support, i can't find this anywhere, but was wondering if there is a way to configure the windows sound sc uses for example, every time i close the chartbook, it does this chime coincidentally, i've been using that same sound to alert me of something important from another program is there a way to shut off the sound when i 'close chartbook' in sc? or to configure sc to use another sound? thank you very much |
[2021-02-02 06:00:24] |
for example, every time i close the chartbook, it does this chime Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-02 06:34:31
[2021-02-02 07:46:33] |
Ackin - Posts: 1865 |
i can't find this anywhere, but was wondering if there is a way to configure the windows sound sc uses for example, every time i close the chartbook, it does this chime coincidentally, i've been using that same sound to alert me of something important from another program is there a way to shut off the sound when i 'close chartbook' in sc? or to configure sc to use another sound? Change notification settings in Windows 10 https://support.microsoft.com/en-us/windows/change-notification-settings-in-windows-10-ddcbbcd4-0a02-f6e4-fe14-6766d850f294 Change notification settings in Windows 7 change the sound to another "unobtrusive" or turn it off completely in the settings in the control panel |
[2021-02-02 20:27:49] |
problem is sc and the other program i'm using is sharing the same windows sound however, the other program i have is meant to alert me when somehting imporatnt happens... i can't just shut off that sound in windows :( |
[2021-02-15 16:17:37] |
User740269 - Posts: 3 |
It is the Background.wav that is played, part of the Windows standard soundfiles and used in Windows as a hint that user input is required. It is played every time you want to close a chartbook. Then the dialog box appears, asking you "Do you want to save changes to ... " Turning it off in Windows sound settings does not help. It keeps playing. Hence, there must be a command in SC that triggers that soundfile. It is pretty annoying having to hear that crappy noise twenty times every evening. That was not the case in previous versions of SC (i.e. 2123) |
[2021-02-26 12:03:22] |
It is the close Chartbook prompt causing the sound. That is from the operating system. That should not happen. We have to look into this. This will be solved in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-26 12:10:43
