Date/Time: Sat, 27 Apr 2024 10:24:16 +0000
Lost data connection every hour
View Count: 937
[2014-02-24 17:13:17] |
User49270 - Posts: 48 |
Hi, I loose my data connection to Openecry at least once per hour at approximately 47 minutes and 45 seconds past every hour. On the log I receive a message: Windows error 10053.(An established connection was aborted by the software in your host machine. Socket closed). It successfully reconnects after multiple attempts within 20 seconds. Thank you.
[2014-02-24 17:55:00] |
We will let OEC know about this.
[2014-02-24 17:59:01] |
Thank you
