Date/Time: Sat, 27 Apr 2024 18:55:59 +0000
Default settings
View Count: 928
[2014-02-24 16:24:30] |
User33552 - Posts: 23 |
1. how do I set a default line style (color, dots/dashes/etc,width)? 2. How do I set a default opening chartbook? 3. Can I set the opening default chartbook to more than one chartbook as "default"? If so, how please? Thank you |
[2014-02-24 18:13:53] |
1. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#CustomDefaultStudySettings 2,3. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#FilesToOpenOnStartup Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
