Date/Time: Sat, 04 May 2024 01:13:04 +0000
Delayed data needed.
View Count: 451
[2021-01-29 15:34:03] |
lorantnagy - Posts: 1 |
I would like to study the relationship between the futures and spot markets. I can only access delayed futures data and realtime forex data. Can I somehow delay the forex data feed, so that the futures and spot markets are aligned and are consistent regarding timestamps.
[2021-01-29 15:53:20] |
John - SC Support - Posts: 31362 |
Sorry, but what you want to do is not available. But, you can use the Replay feature to have your charts in sync and do your testing that way. Refer to the following: Replaying Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-30 11:12:37] |
You might want to have a look at using this study on one of the delayed symbols to overlay a real-time Forex symbol: Add Additional Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
