Date/Time: Fri, 03 May 2024 07:02:59 +0000
I can't find the Range Bars ....
View Count: 1180
[2014-02-24 00:58:42] |
Auspicatum - Posts: 46 |
Could you please direct me to where they are? I would assume it would be in "chart settings" in the drop down menue, that also holds "candlesticks", "Renko", etc... but alas I do not see it. ??? I looked at the pricing info for packages, and I haven't seen anything that mentions Range Bars Specifically. Thanks again for your time ! |
[2014-02-24 04:07:20] |
Infinite - Posts: 134 |
Just left mouse click on the chart and type in the number of your range bar and r....like this 8r then hit enter
[2014-02-24 05:30:07] |
....yeah I found it. Thanks. It was in a drop down menu in the upper center of the "chart settings" page. (not the one to the lower left). |
[2014-02-24 09:40:22] |
See: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
