Date/Time: Tue, 30 Apr 2024 16:35:26 +0000
Currency display
View Count: 1082
[2014-02-23 15:43:49] |
G. Thierstein - Posts: 7 |
Since I have downloaded the new version, I have problems with the trading activity log and P/L display in the chart. In Chart: P/L should shows "0.68C after the trade" instead of P/L "$80 - commission" . The P/L display during the trade is correct ! And the trade activity log shows points only. It is set for Currency please advice |
chart for Replay-backtest.jpg / V - Attached On 2014-02-23 15:42:47 UTC - Size: 241.18 KB - 380 views TradeActivityLog.dat - Attached On 2014-02-23 15:43:13 UTC - Size: 10.07 KB - 313 views Attachment Deleted. |
[2014-02-23 21:05:12] |
Before we start looking through your Trade Activity Log, refer to the documentation about this here: http://www.sierrachart.com/index.php?l=helpdetails77.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-23 21:05:32
[2014-02-24 20:58:58] |
followed your advice. still have same problem. I am using a fresh installation for 1094 and transferred data from 1077. I made a fresh installation to make sure. Version 1077 works without problems. Only version 1094 gives me the problem. I run another test trade with 1094 after working through the helpdetails77. As mentioned no change. During the trading process the P/L shows the accurate "win - commission" and when the trade finishes the value changes. |
[2014-02-24 21:42:36] |
What is the symbol you are trading? And what is the order quantity. And what Data/Trading service are you using? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-02 13:13:38] |
NQZ3 it replays but counts wrongly NQZ4 and NQZ14 do not replay at all |
[2014-03-02 20:42:01] |
1. Update Sierra Chart to the current version. 2. For correct Profit/Loss values only use the symbols that you currently see listed in File >> Find Symbol. You need to have selected the correct Service in File >>Data/Trade Service Settings which correspond to the symbols you are using. 3. In the case of the Sierra Chart Historical Data Service, for futures contracts, the years are two digits. Only use those symbols. There are no Symbol Settings which are necessary for correct profit/loss calculations, for single-digit years. 4. We are not quite sure what the replay problem is you are having. For the documentation for this, refer to: https://www.sierrachart.com/index.php?l=doc/doc_ReplayChart.html 5. Once again, if you continue to have a problem, review the information given here and make sure you have the proper Symbol Settings applied to the chart: http://www.sierrachart.com/index.php?l=doc/helpdetails77.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-02 20:42:29
