Date/Time: Mon, 29 Apr 2024 15:32:33 +0000
Opening Chartbook groups? (but not at startup)
View Count: 2139
[2013-04-19 06:57:20] |
PhilipJames - Posts: 34 |
How do I set up a group of chartbooks, so that I can open several chartbooks all at the same time? I know a set of files to be opened on startup can be listed under Global Settings/General Settings in order to open files every time Sierra is started up; however I don't want to do that every time I start it up, but I will frequently (not always) want to open a chosen group of them part way through an existing Sierra session, but not initially. Thanks. |
[2013-04-19 07:12:38] |
This capability does not exist. But recently opened Chartbooks will be listed on the File menu on the right side.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-19 07:12:52
