Date/Time: Sun, 28 Apr 2024 15:42:28 +0000
Problem with "Open trade window for chart"
View Count: 1860
[2013-03-21 22:06:11] |
natanibz - Posts: 131 |
Hi, i try to open the Trade Window for Chart but i don't find it. This after i removed one monitor. How can i do? Thanks. |
[2013-03-21 22:26:11] |
Go to the chart that it is associated with and select Chart >> Reset Child Windows.
[2013-03-22 12:22:51] |
Perfect, thanks. |
