Date/Time: Wed, 04 Nov 2026 15:41:09 +0000
NGH21-NYMEX - Symbol Error
View Count: 805
| [2021-01-20 18:07:44] |
| User907968 - Posts: 885 |
Hi, NGH21-NYMEX is not streaming for some reason, historical data downloads ok, but chart does not move, DOM is empty and quoteboard is all zeros. Excerpt from msg log: SC Data - All Services | Received security definition for symbol NGH21 | 2021-01-20 12:01:29.795
Symbol Error - NGH21-NYMEX is unknown, unavailable, or improperly formatted. Already subscribed to symbol. New subscription rejected. | 2021-01-20 12:01:29.795 NGG21-NYMEX works correctly, so does NGJ21-NYMEX. |
| [2021-01-20 18:39:10] |
| John - SC Support - Posts: 48419 |
The first thing we want you to take care of is to connect to your Trading Account in order to validate the account for the CME Group. Our information is showing that today is the last day of your validation. Although it doesn't fit with your description, we still want to make sure that this is taken care of so we can rule it out as an issue. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Once that is complete, then try to see if you can get the data for NGH21-NYMEX. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-20 19:42:52] |
Ok, it is working now, seems there was a historical chart that had the old symbol format, I assume this was causing the problem? Sorry to waste your time. |
| [2021-01-20 20:34:53] |
Yes, that would definitely cause the problem.
