Date/Time: Wed, 04 Nov 2026 15:40:04 +0000
Header with Synbol Icons vs Lettered Icons - TransAct Migration
View Count: 780
| [2021-01-20 02:56:52] |
| User388297 - Posts: 11 |
Hi Support, 1) In migrating from TransAct to one of your reco'd vendors, I'm trying to identify what configuration file(s) I need to copy over to newer SC in order to keep my old header icons which use Symbol Icons (*.jpeg attached) instead of the default Lettered Icons. Copying all of the files is untenable since I’m currently using my vendor’s CQG feed. What specific file should I copy over to keep my old Symbol Icons? 2) Speaking of CGQ, I plan to transition to your reco’d Denali feed at the first of the month. Any special instructions/"how to" links you can post? 3) Additionally, the TA Sierra Charts had a something they called a "big board" or "scoreboard" or something like that which handily included the previous closing price? That's the only thing so far I miss from TA and trust that you can tell me where to find this previous closing price in this post-migration SC version I'm working w/ now? Regards, AC13.... |
Private File |
| [2021-01-20 15:05:05] |
1. You need to copy the Sierra4.config file and the files in \Graphics\Buttons. Do these when Sierra Chart is not running. 2. Here is the documentation for this: Denali Exchange Data Feed 3. Refer to this page: Getting Quotes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
