Date/Time: Wed, 04 Nov 2026 15:41:24 +0000
Numbers Bars Calculated values 2
View Count: 1156
| [2021-01-19 15:48:44] |
| User781913 - Posts: 12 |
Is there a way to show a negative value of "Sum of Ask Bid Pull/Stack Value" in the Numbers Bars Calculated values 2 study?
| [2021-01-19 16:25:48] |
| John - SC Support - Posts: 48419 |
We are not understanding. First, there is not a subgraph for "Sum of Ask Bid Pull/Stack" in the Numbers Bars Calculated Values studies. Second, the subgraphs that are available display the negative values when the Pulling/Stacking for that particular subgraph is negative. So there is no issue with the negative numbers. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-19 16:26:14
| [2021-01-19 17:13:22] |
I was referring to the "Ask/bid pull/stack sum diff" subgraph in "Numbers Bars Calculated Values 2" study. I wanted a column to be the opposite sign of this subgraph, i.e. when it's -10, I want it to display +10. In other words, can I configure a formula using these subgraphs to derive new subgraphs?
| [2021-01-19 17:22:24] |
It is possible to take the value in that subgraph and manipulate it using the various Arithmetic Studies. This would then show you the plot of that data in a separate region. Refer to the information here: Using the Basic Arithmetic Studies In terms of other display options, you could use the Text Display for Study to show the most recent bar value. Refer to the information here: Text Display For Study Or you can use the Study/Subgraph Above/Below Bar as Text study. Refer to the information here: Study Subgraph Above/Below Bar as Text It is not possible to have it in the grid of the Numbers Bars Calculated Values. You can create your own Numeric Table using ACSIL. Refer to the following: ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-19 17:22:39
