Date/Time: Wed, 04 Nov 2026 15:39:48 +0000
Alternatives To Interactive Brokers
View Count: 1287
| [2021-01-19 14:22:27] |
| User184576 - Posts: 23 |
Hi, I will be leaving Interactive Brokers not soon enough. I would like to trade domestic futures, as well as international (Asia specific) futures. From a technical standpoint, what configuration of data and brokerage would you recommend? What brokerage, in your opinion, has it's shit together? Who do you enjoy working with the most? Thanks! |
| [2021-01-20 04:27:21] |
Being you require Asia futures, you may want to look at using AMP (Just do a search for them). And you would need to use CQG for order routing: CQG Trading Platform Service Definitely use the Denali Exchange Data Feed for the US futures: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-20 15:08:37] |
Thank you - I appreciate it!
