Date/Time: Tue, 30 Apr 2024 21:13:32 +0000
[User Discussion] [Locked] - CRYPTO CURRENCIES
View Count: 1710
[2021-01-15 14:17:25] |
User260614 - Posts: 4 |
How do I open a btcusd and other crypt charts? I am having problem
[2021-01-15 15:10:38] |
John - SC Support - Posts: 31235 |
Refer to the information here: Cryptocurrency / Bitcoin Data and Trading Services: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-16 09:27:39] |
This is what I get when trying to open Crypto Charts. How, for example, can I open a BTCUSD chart? http://www.sierrachart.com/image.php?Image=1610789194622.png Thank you |
[2021-01-16 09:31:32] |
Above image did not have the overlay. Consider this one here http://www.sierrachart.com/image.php?Image=1610789465175.png |
[2021-01-16 23:59:09] |
Use this symbol: XBTUSD-BMEX Open a chart for that symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-16 23:59:41
[2022-08-29 14:03:21] |
whats1thingnow - Posts: 407 |
just to confirm: XBTUSD-BMEX on sc = BTCUSD (bit coin spot market)? also curuios, what is XRPUSD-BMEX? thank you very much |
[2022-08-29 14:23:20] |
Sierra_Chart Engineering - Posts: 14159 |
Those are BitMex symbols. You need to contact BitMex with your questions. We cannot answer them.
