Date/Time: Sat, 27 Apr 2024 16:28:29 +0000
Which package to select
View Count: 593
[2021-01-14 16:12:22] |
eaglefutures - Posts: 40 |
Hello Support I was in the process of renewing. I see there are now different package combinations, and I am not sure what to pick Would I still be able to add data with the Standard Package 3 at a later stage if I dont want real time data immediately. Or do I need to select package 10 which is Standard + Denali do I select then Package 3 + the Denali Fee (25 ) + Exchange Fee ( CME ) Or do I have to select Package 10 + the Denali Fee (25 ) + Exchange Fee ( CME ) |
[2021-01-14 17:52:33] |
Sierra Chart - Max - Posts: 5597 |
For now go with the following options: do I select then Package 3 + the Denali Fee (25 ) + Exchange Fee ( CME ) Sierra Chart Support |
[2021-01-22 15:36:22] |
Hello I reviewed the exchanges presented There is a billing option for the CME group at a low price of 3.25 which doesnt have market depth. Is this still able to show numbers bars or tick by tick data. I dont require the market depth Other than the market depth is it complete and the same as the CME package for 31.25 Thank you |
[2021-01-22 22:27:28] |
Those two exchanges (Full CME Group and Full CME Group with Market Depth) are the exact same data apart from the Market Depth. Numbers Bars do not use the Market Depth. Numbers Bars is using the actual traded Bid and Ask information. It sounds like you can just use the Full CME Group at $3.25. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
