Date/Time: Wed, 04 Nov 2026 15:53:02 +0000
Rejected orders
View Count: 893
| [2021-01-14 02:15:15] |
| User123179 - Posts: 28 |
HI im having issues with orders being rejected, error message reads - Price must be greater than zero order ID M6AH1 has no positive price etc. Is this an issue that I can fix or do I contact my broker AMP ? My Enable fix logging is checked. Seem to be only having dramas with 6A not ES. Im also charting on the main contract but executing on the micro but through the main contract that is not part of the problem is it? Regards Hayden |
| [2021-01-14 04:50:17] |
The solution to this is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#UsingTradeSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
